I'm installing a relay for Charging RV battery (DC to DC charger).
GOAL is to Charge RV Battery while minimizing risk of Dead JKu Battery.
Relay operation requires >10.4Volts and consumes 0.2 Amps to operate.
So, would like to Close the relay Only When Battery has Sufficient Charge.
Need to tap a wire under the hood that will be "12Volts On" But, only when battery is sufficiently charged.
Ideally, this would be a source near the battery or engine fuse box.
Welcome any suggestions.
Sincerely,
Doghouse
Sincerely,
Doghouse
