I bought a pair of JKS correction brackets for the front of my Jeep.
The driver's side bracket slides right in. The passenger side bracket fails to line up to the tune of about 1/4".
I called JKS and their tech told me to cut the inside of the control arm mount to clearance the bracket.
I asked why I should need to go that route. He told me that the brackets are mirror images of each other, though the mounts on my 2015 jku rubi are slightly different from left to right. I was/am dubious...
Wondering if any of you have encountered this issue?
Thinking about just returning the JKS drop brackets and buying a full set of adjustable short arms- which is what I probably should have done in the first place. I don't want to cut meat out of my control arm mounts that will commit me to running these brackets permanently.
In that case, what are your recommendations for a full control arm kit for a 4.5" lift?
