JK Rubicon fluids and brake service reality check
Nericson
2014 JK Rubicon. 42K original miles. After oil change at dealer they tell me I need to do all the brakes, replace the brake fluid, differential and transfer case fluid changes.
Am I getting "milked dry" for no real reason here?
BLACKJKU
Moderator
Huntington In
You are if your letting the Dealer touch your Jeep. If you looked at your Owners manual it tells the intervals at which the fluids and most other things should be changed.
The brakes are easy to tell when they need to be replaced, a squealer will alert you or a visual check.
kk2010jk
Milford NJ
Every time I took my cars in for Tires (3 cars this year) they always come back with you need new brakes. As said above, brake fluid you can visually see if it's dirty. Pads you can worm around on the ground and see how much pad is left.
Oh and each of these cars were 60%+ left on the pads
Reactions: Speartip
JerryD
¯\_(ツ)_/¯
West Michigan
Yes, they are. BUT... I would do a full brake fluid change if it's never been done. Brake fluid can absorb moisture over time and even though it's low mileage, if it's over 2 years old it's likely due. A inexpensive tester can test the boiling point (think water content) of brake fluid to confirm.
Vman
Pacific NW
Learn to do it yourself.
Differential and transfer cases couldn't be more simple to do. If you just bought it I would definitely replace all the fluids.
New fluid is a lot cheaper than a ruined diff/transfer case.
I used lube-locker gaskets on my diffs instead of RTV and now changing the fluid on both takes less than 30 mins.
For the transfer case, all you have to do on a stock JK is remove 4 bolts and drop the skid plate to gain access to the drain/fill plugs. Super easy.
If you have an auto transmission, I'd look into getting the fluid and filter replaced as well. That's a little more involved but I wouldn't classify it as a difficult do-it-yourself.
terdogjk
Elko NV
It's been an actual record setting winter here in Elko. 4' of snow to date. Been plowing an awful lot with Roxy.
It's time to do all the funds.
Is ATF the best option for the T case?
Reactions: Speartip and mrjp
terdogjk
Elko NV
Ya, that's the info that I have as well.
For years I've used ATF in 2 stroke dirt bike transmissions.
Just wondering if there's something better.
I found a seller on Amazon that has a 6 pack of Mopar ATF4+ for $50 shipped. It's supposed to be here today.
This afternoon will se me in my shop doing front diff, rear diff, T case and engine oil.
Thanks guys.
Reactions: Speartip
SteveF
U.S. Coast Guard Retired
Eastford CT
They don't call them Stealerships for nothing
