Good Morning
I am the original owner of 2009 Jeep JK with the 3.8 V6 engine and a 4 speed automatic transmission. The vehicle mileage is just under 175K. I have what I believe is a range switch or neutral positioning switch that needs to be replaced or adjusted. The Jeep occasionally will not start unless you wiggle the gear shifter position lever. I'm having to do this more frequently.
Has anyone here had a similar issue and how did you repair the problem? What is the degree of difficulty replacing the switch? I did a site search without finding anything specific.
Thank You
Mike
Thank You
Mike
