I have a problem with my 2017 Jeep Wrangler 68k .. After driving it with in a short time being off it will turn over but not Run . If it sits for hour or two it will Run .
It will Run after sitting off for a long time - overnight , while at work all day. If it runs in park for 30 minutes are more it will Run , has to be moving for it to not run the next time its turned off . No check engine light
The Battery is good , replaced starter and Cam/Crank sensors, ck fuses box and wire connections to fuse box.
It wont Run in Neutral..
Any suggestions
Any suggestions
