How to get to gas tank top (fuel pump & Evap connectors) in a 2018 Wrangler JKU without dropping the tank. Can it be done?
You mean, like the same way you access the fuel pump in pretty much every car build in the last 20 years?Why wouldn’t Jeep plan for fuel pump issues or Evap line issues that can be fixed without dropping the gas tank!!
They think everyone will just run to the stealerships when their jeep breaks down.Why wouldn’t Jeep plan for fuel pump issues or Evap line issues that can be fixed without dropping the gas tank!!
I didn't disconnect anything because I used the ratchet strap method.Macguyver did u disconnect all the connectors on top. Just wondering about putting pressure on those and the nipple ( did I say nipple?) and did u use the ratchet strap method?
Hardly any automotive engineers seem to consider working on the vehicles they design. I used to drive a 1960 Ford 1/4-ton with a straight 6. I could climb over the fender, straddle the front axle and work on anything in the engine compartment. Definitely liked that truck but no good with a family.Why wouldn’t Jeep plan for fuel pump issues or Evap line issues that can be fixed without dropping the gas tank!!
