Hose clamp
Rachel71
Columbia S.C
I have a 2010 Jeep Wrangler Rubicon and I noticed the hose coming from the top of the engine which I am assuming is the breather hose which runs to your air filter box, it had came off the end that goes to the air filter box , is there meant to be a hose clamp at that end or would a zip tie do thanks
There is supposed to be a hose clamp (just doubled checked mine). The intent is to keep it in place. I might would use a zip-tie as temporary solution, but in the long term I’d replace with a hose clamp.
Okay thank you so much for your reply on this , I assuming just a regular size hose clamp will do?
