I’m having a hard time diagnosing this high pitch grind. I only hear it when accelerating around 2000 RPM then goes away at higher rpm/speed. It only happens when the vehicle is under load. It doesn’t matter what gear I’m in, it almost seems as if it’s related to the pedal position. I’ve put the rear of the vehicle on jackstands and accelerated to the RPM that it usually happens with no noise. I ran it up and down a wall on both sides, and it definitely sounds louder on the passenger side.
I replaced the hub assembly when I got a speed sensor code but that didn’t fix my problem.
I removed my front drive shaft and the noise is still there
I took a video while power braking to check motor mounts. Does the engine movement look acceptable? Also, I’m hearing a whine when power braking but not sure if it’s the same thing I’m hearing while driving.
Any help would be greatly appreciated
