Going For Build #2 on My 2012 JK
DesertHound2012
DesertHound
Apple Valley, California
Hello, all It has been a good time the 6yrs learning about Crawling & building my JK, But after 6yrs and 100,000 miles of 97% hard miles, it is also my 1st with not to much input my own doing from others (and yes it cost me more then I care to say still one best time of life!!
Now it is Time for the last Build #2
I did learn the Hard Way mostly $$$$$$ LOL this time I have recruited someone with more knowledge oh and more connections.
but still I need to learn and do my due diligent so i can do repairs after the build is compete.
going to start with LS, trying to away from Jeeps Problems under the hood to many to mention. LOL
I know 0 about LSing my JK can Some one inform me of a good place to research motros and install info or any info that would help me get started in the right direction??? thanks to this Forums from all of you Have A Marry Marry & Happy Happy
To be fair, an LS is just as likely to have problems as any other engine. But don't let that stop you.
Your best bet, if you're new to this sort of thing, is one of the "all in" LS swap kits available. You'll get the engine, transmission, transfer case, mounts, and all the wiring and computers to make it work.
Bear in mind that your axles are likely going to be problematic. I've got a 500HP 392 Hemi in my JL. The D44's hold up pretty well, but they've been beefed up from the standard Rubicon axles. I also think Jeep made a wise choice when they used a full time 4WD transfer case in these monsters. Splitting 500HP between two D44's is going to be a lot more reliable than sending it all to the rear. And if your base rig isn't a Rubicon, you're just asking for trouble.
The other option, of course, is to swap in a set of D60's or something of that sort.
Reactions: DesertHound2012
TY Very Much it's a starting point. your so Wright about the axles i have put more then 1 on the front end this build i will go 60s front & rear.
happy holidays & a much better year for All
This is what we like to see! We are experts in LS swaps in Jeeps and have the parts, information, and expertise to help. Whether you purchase from us or not, we are happy to help. Start with our website, https://novak-adapt.com/index.htm and feel free to call, email, or message us on the forum anytime with questions.
Best of luck with your build!
-Dustin
If you go the LS swap route, go with a Holley Terminator MAX X. I went with RPM extreme and there are ALOT of bugs with tuning and differences with the Jeep and Chevy components working together Like AC, Engine cooling, voltage/charge the battery. I also recommend a MechMan alternator, they are amazing and cut a lot of the charging headaches.
We have solved a lot of the same issues with our wire harness modifications to the OEM GM harness as well as our programming for the OEM PCM. In addition to our sensors, tach emulators, etc. everything functions as it should and is all included in our powertrain kits or available individually.
-Dustin
