Flow valve to canister hose discontinued
jaijak
Hello all, I am trying to resolve some codes my daughters 2007 Wrangler JKU is throwing. The concerning codes are the EVAP system codes such as P0456, P0457, So upon inspection of the EVAP system starting with looking under the rear of the vehicle where the Canister is. That is when I noticed there is no Canister in that area. That isn't the major issue. The major issue is that the Flow Valve to Canister Hose is irreparably damaged. I can replace all of the parts BUT that hose. That hose has been discontinued as of a t least a year ago. The part number is 52126036AB. Does anyone have a work around, to replace or fixe this hose, or to remove the codes if that hose isn't there? any help is greatly appreciated. Thank you in advance.
