Fast turn signal (Intermittent)
DevilDawgJK37
Southwest Missouri
07 Sahara 2 Door
I have stock signals and headlights. Intermittently, the turn signals will flash fast because the front signals aren't working. I have seen it flash normal for awhile, then flash fast, then it will go back to normal again while going through town. I cleaned the ground wire connection behind the airbox. I thought that fixed it, but then it happened again. Any help will be appreciated greatly! I have seen other people post that same issue on another forum, but no response to the issue.
I think it is because the front ones are not working. I am not sure what causes it to be intermittent though. But I suspect get the front fixed it will solve the issue.
I believe I fixed the issue. The grounding connection next to the breather box was bad. The factory single connection had some wires that were broken. I pulled it and put on 3 separate end and bolted it back on the post. All lights are working properly.
Reactions: Speartip and mrjp
