Replaced Plugs and O2's engine light still coming on about half tank of gas, burning high octan not sure what else to do. 2012 Jeep JK
I have on e OEM O2 the rest NHK which my muffler guy said are good, I guess I will go buy 3 more OEM O2'sDid you use OEM ports?
Did you reset your ECM?
No I have not Reset the ECM, suggestions on how to do that?I have on e OEM O2 the rest NHK which my muffler guy said are good, I guess I will go buy 3 more OEM O2's
What would be a good aftermarket Catalytic Converts?First, stop running high octane fuel. The engine in your Wrangler gets zero benefit from doing so, unless you have done a LOT of modifying.
Now spend the money you save by running the appropriate gas on new catalytic converters.
There are literally a hundred options. If you want to stick with OEM, then pretty much any parts store in the country.What would be a good aftermarket Catalytic Converts?
There are two things I think are near universally true though. Stock sucks, and a chance to fix is a chance to upgrade.
Magnaflow, SLP, Flowmaster... pretty much all the major players in the aftermarket exhaust world make high flow cats. I don't think you can go wrong with any of them.
I still have the OEM cats on the Jeeps. The Vette has a pair from Random Technologies.
I don't know the vehicle inspection rules where you live, but do be aware that it is illegal to change the number or location of the cats, which may impact your options.
