My front windshield washer pump was not working at all so I decided to pull the pump and check it out. I disconnected the negative battery terminal and pulled the connectors on the ECU to access the Pump. I pulled the pump checked it out cleaned everything up and I figured out a temporary fix until I get a new pump. I plugged all the connectors back in reconnected the battery, and now it wont start, does not even click. we have had a lot of winter weather here and I have had the jeep out nonstop over the last few days. I also noticed this connector and wire with nothing connected to it. The connector comes from the far left the harness to the ECU/PCM. It definitely looks like a ground can anybody here confirm that? The connector has some writing on it that says "ALL".
