2012 Jeep Wrangler Sahara Unlimited.
Bought used from small car dealer in 2018 with 95,000 now has 127,000.
Automatic transmission
No major mods except bumpers and leds. Previous owner did put bfg ko2 that are slightly bigger than the stock spare.
Sunday morning: rained overnight maybe 70 degrees. Drove out of parking spot (park to drive) and as I reach about 10mph it gave this jerk like it couldn’t get into the next gear and had a “nnnnn” sound. So I tried to accelerate again and had the same issue. Also while pressing on the brake, the brake pedal shuddered a little bit. So I coasted around the block pulled back into my spot turned it off and got my bf. This time I reversed out of my spot, and when I drove away I had no issues. I drove to work no issues, drove back home from work with no issues except my brake pedal shuddering once.
Monday morning: drove out of my spot again (park to drive) and the issue happened again. When I braked, the brake pedal shuddered again. This time the abs, traction, & downhill assist lights came on. So again I coated around the block, and pulled into my spot and turned it off. I got a ride to work and later we checked the trans fluid and it was a little low so we filled it. Then we took it for a ride, reversing out of my spot and into drive and no issues. The abs traction and downhill lights didn’t come back on.
Tuesday morning: Again pulled out of my spot (park to drive) and issue happened. So then I reverse a few feet in the road, and then drove it and it didn’t happen. However without further risking it, I got a ride to work.
If I reverse and then drive I have no issues. If I drive from park I get the jerk going into second gear.
