Does the engine wiring harness have a fusible link?
Did you actually take the connections apart and look to see if there is any corrosion on the pins. From everything i've read it has to do with a poor connection.
I have checked all known connections, still have the same problem. What are the long shots?
As it turns out, the dealership sold me a
bad throttle position sensor.
This problem has been solved.
Thank you for your help.
Thanks for updating us, I thought the throttle position sensor was in the Throttle Body and was sold as a unit.
I have a new question. What exactly does the P0523 circuit high input for oil pressure sensor mean. I have replaced the sensor and checked the connection.
