Is the power to the throttle pedal or throttle position sensor fused? Trying to find the cause of low voltage input.I'm not aware of any motor vehicle using a Fusible link since the early 90's.
2012What year is your JK and is there a CEL for this?
I will clean them again and checkDid you actually take the connections apart and look to see if there is any corrosion on the pins. From everything i've read it has to do with a poor connection.
I have checked all known connections, still have the same problem. What are the long shots?Did you actually take the connections apart and look to see if there is any corrosion on the pins. From everything i've read it has to do with a poor connection.
As it turns out, the dealership sold me a
bad throttle position sensor.
This problem has been solved.
Thank you for your help.
It is. Comes as one unit. Had wire harness tested, and that was the result. After replacement again it works.Thanks for updating us, I thought the throttle position sensor was in the Throttle Body and was sold as a unit.
