Does any one have a wiring diagram for a 2013 Jeep Wrangler Unlimited?
Any specific area, system? I might have one. If I do it may be 2015 and higher not sure if there is a difference.
a 2009 is going to be vastly different. Interior was changed in 2011, Engine was changed in 2012.
What specifically are you looking for? In 2012 jeeps basically went to fully modern electrics and even before that pretty much everything is controlled by the computer. No more changing out a gear to change the speedometer. An app is needed to make adjustments to settings. I'm unsure if there is a fully complete schematic out there out side of something available to dealers /mechs
The more info you give us, the better we can help.
I have some wiring diagrams 2015, but they are for a system not for the wiring harness. For instance the one below is for A/C system.
you can also get any wiring diagram at the Escondido Library.
https://www.escondido.gov/162/Library
select digital resources.
select Chilton Repair
enter the library name "escondido"
then enter your search vehicle.
Might have to wait a day or two. A 5.2 earthquake has that part of the state scared to work. Centered in Julian (a very fine wheeling destination) about 2hrs ago.
