Disable ABS ?
crazyshadow
canada
Hi,
On my 09 wrangler JK, my rear left parking brake broke and rubbed the tone ring of the wheel speed sensor, resulting in a faulty sensor reading and ABS light coming on and off at random.
The problem is I cant get the repair done within couple weeks and I need to drive it. the ABS kick in randomly and I fear to break something.
Can I just disable the ABS module for few weeks without messing anything?
I have Jscan and OBD reader to disable it
My ABS/ESP light has been on for almost a year now and no issues, haven't checked to see what is causing it. All I know is im glad because I don't like either of the functions. Only downfall of the ABS light being on is I don't have cruise control.
Not having ABS you'll have braking like normal unless you loose traction when coming to a stop and if you know how to drive that shouldn't be a problem.
I hear grinding noise when ABS is on (light off) and the noise disapear once the system turn off ABS ( light on) .
So i prefer to turn it off completely to avoid damage
Thanks for the info, i will try to turn off completely with JScan until i can get it repair
Does it disable it with the fuse pulled? I'm not sure if J-Scan can disable a safety feature.
It seems to work now, the ABS is disabled and stay disabled, it doesn't kick on/off anymore.
I didn't use the ESC kill function as shown in the video from last post, There is also an option to turn it off in the module control
Thanks!
Reactions: mrjp and BigAL07
Thanks!
Does your cruise control still work?
And vote CP! IF you are truly Canadian (crazyshadow?) and own a Jeep JK, that ass PM of ours will ban it after he takes our hunting rifles.
