After almost a year of not enjoying my 2007 JK Wrangler X ,6cyl, auto. A/C it's a given serious problems exist. Started with gauges and steering column controls were dead and A/C didn't work. Then sent off the TIPM for repair and everything worked except had warning lights on- stability control, traction control, air bag, and A/C didn't work. drove a couple times then Jeep was dead where I parked it. Dead battery...trickle charged Red Tops per instruction. Started but only had 2nd gear. Battery drain in 1 day and then went completely weird... no power when key is on unless you step on the brake then dash lights up but nothing...no start-dead. Sent TIPM off again and it had 3 definite issues that were corrected but I'm unwilling to install now until I find the culprit. Wiring short??? Ignition short?? It all started with the column so??? I'm willing to install a column wire harness and under hood harness but have not found one exactly like mine. Dealer says not available. Any suggestions. Even considering pulling the motor and doing a swap but HAVE to stay budget minded. With that suggestions on how to get dash gauges, A/C and trans to work doing a swap? HELP!
