Dash lighting up crazy
Apoorman1
Utah
My dash lit up like this tonight. Everything functions normally though. I tried tightening the battery terminals. It doesn’t come on immediately but only once I get moving. Am I screwed?
Make sure they are clean. While we still have the stock clamps they don’t work well. Also have your battery tested, a bad battery will cause issues.
Reactions: BigAL07 and mrjp
Definitely go through and remove , clean and reinstall your grounds. One behind the right headlight, one on left fender by the PCM, one by the battery box and the fuse box, engine ground on the engine next to the battery, but below the valve cover(this one is easy with the inner fender removed). I've been chasing all them dang lights and found most ofy ground posts needed cleaning.
Cheers!
