I am attempting to change the coolant on my 2016 Jeep JKU and I am using distilled water to flush out the coolant system. However when I am trying to drain the coolant I am only getting about 1 gallon out (Radiator drain and Removing lower radiator hose). Is there anyway that I can drain out the whole system in a different way because I am pretty sure that this system takes about 3 gallons of coolant.
Edit: I do not want to knock off the 50/50 mix
