Hey, I'm new to the forum. I hate to even ask because I know it's been asked 1,000 times but can someone point me to a thread showing wheel size and various lifts please. thx
ok, one more question: with a two inch lift will I need longer brake lines or are they long enough to handle the limit of flex this kit provides?This lift includes shocks, which you will need if lifting unless you use relocation brackets for your current shocks.
Rancho 2in Sport Suspension System with RS5000X Shocks for 07-18 Jeep Wrangler Unlimited JK with RS9000XL Shocks for 07-18 Jeep Wrangler Unlimited JK
Rancho® is proud to offer a new 2-in. Suspension System for the Jeep Wrangler JK Unlimited. The 2-in.www.quadratec.com
It’s my understanding that this kit is all you need. However, some add longer front lower adjustable control arms or geometry correction brackets. As well as front and rear track bars.ok, one more question: with a two inch lift will I need longer brake lines or are they long enough to handle the limit of flex this kit provides?
Chris, I kindly disagree with your assessment of the Rancho 9000 shocks. For the slight price increase, they are worth it from all the research I have done. Being able to tune your ride quality from soft like an old Lincoln Town car to a firm ride is a great option. The 5000’s are nice, but those who have experienced both would not pass on the 9000’s.If you buy the Rancho one, it's cheaper here on Amazon:
https://www.amazon.com/dp/B06XYSK5F6/?tag=jkforum-20
I hate Quadratec, so I do anything I can to avoid them.
Also, that Rancho lift I linked to has the RS5000X shocks, which I personally recommend. The 9000 shocks in the other version aren't bad by any means, but just unnecessary.
Another good 2.5" lift is the AEV DualSport lift.
You will NOT need longer brake lines with that kit.
Yes, I've owned both the Rancho RS5000X and the 9000 models. I like them both, but I found the adjustment on the 9000 models to be pointless for my needs. I played around with all the settings for about a month, but finally just found the right setting, left them there, and never messed with them again.
So having had experience with both, I would pass on the 9000s myself
But for those who constantly like to tweak their shock settings, then by all means, go for it.
The RS5000X is am amazing shock in terms of ride quality, right out of the box.
