New to this forum so I apologize if this topic has been discussed in another thread. I have a 2012 JK Sport that I have been doing modifications to for years now. The other day as I was driving, I took a turn and when I let the clutch out and pressed the accelerator, the Jeep just bogged down and the dash lit up like a Christmas tree. Luckily I was very close to home and nursed it back to my driveway. Since then I have pulled 13 Codes (many repeats) with P2122 being the Primary. I went ahead and replaced the Accelerator Pedal Sensor since my code reader suggested that may be the issue. That did nothing! So I did some research and found that it could be the TPS Sensor, which for mine means I had to get the entire Throttle Body. Replaced that and nothing is better. I pulled every fuse and examined them, nothing looks blown. I am hoping someone on here may be able to point me to something else to check/replace before I give up and take It to a shop (I really would rather fix myself). Below are all the codes that are current, it had 0 codes that I am aware of before this issue.
P2122 - Primary
P0520
P0335
P0642
P2135
Any and all suggestions welcomed. Thank you in advance!
P2122 - Primary
P0520
P0335
P0642
P2135
