Hi. This is my first post so I hope I don't babble too much.
I have not been able to find any info on this issue. Everything is related to abs, tcs and stability control lights not turning off.
When I start my 2016 JK sport and the dash lights go through their check my abs, tcs and sc lights do not come on.When those systems are activated, snowy slippery roads, the lights do not flash. When I press the tcs button nothing happens. In 2 wheel, 4 wheel high or low range. When I press and hold it for 7 or so seconds I do get a message the stability control is disabled. I checked the lights with JScan and they do work. I have tried a full dashboard scan and those lights do not come on. There are no codes active. I have pulled both main fuses for abs and tcs and that did disable everything including my speedometer and a few other things but the dash lights did not come on.
The front axel assembly was replaced with factory axel and that is when the problem began. I had the jeep back to the body shop, they could not find any problems.
I live in Ontario and it helps to turn these features off in the snow some times. I'm not sure I want to put in a bypass switch.
Appreciate any help.
