Brake booster performance code after replacing booster
Cosmo5754
Michigan
I recently replaced the power brake booster, brake booster vacuum sensor, brake light switch, and air pump. After completing this I did a brake flush and bled all of the calipers. I am still getting a stiff brake pedal and a C0021 code. After replacing the brake booster with a second new unit there was no improvement. While on the test drive after the second brake booster I got a U0414 code and the car started acting sluggish. Car seems to be in limp home mode and the transmission refused to let me shift it using the auto-stick, but I confirmed that the 4WD is still functional. After letting it sit for an hour that has gone away. I have replaced everything in the power braking system minus the master cylinder so I don't really know where to go from here. Thank you!
2014 Wrangler Unlimited Sahara 3.6
What were the issues BEFORE you replaced the parts?
By stiff pedal you mean no power boost?
I’d be looking at the vacuum lines and check valves for a vacuum leak.
