I think you may be fine. I am not sure what all is affected by a body lift, but essentially when you do a suspension lift everything else is basically raised, except the axles. I think you would need to check for brake lines, breather / vent hoses (from differentials), wheel speed sensor wiring, things like that may need to be adjusted as some of them might actually end up being 4.5”-5” of difference from stock (2” + 2.5”). I am not sure what a body lift does to the steering assembly in conjunction with the body lift and suspension lift.
