Best LED Headlights
Runner51761
Illinois
Hello,
I want to replace my stock headlights (2016 JKU) with LED headlights. Is there a pair out there that is basically plug/play and that will fit where I have to do no modifications to get the new lights to fit? Any help would be greatly appreciated! Thanks!
The pair I bought several years ago are no longer available on Amazon, but these are the shown replacement and look very similar to mine. The only issue I had with mine was both headlights are identical and the tabs on the rear of the light housing don't line up with the slots on the headlight frame in the grille. But that was a quick fix, 30 seconds with a razor knife to trim it down.
Took longer to adjust the headlights than installing them. They are much better than stock.
https://www.amazon.com/dp/B0BJF3LR9N/?tag=jkforum-20
They aren't the halos (not a fan of halos), and they are available in all black, all chrome or black and chrome. I went all black and changed the trim rings around the headlights to all black.
Reactions: WSS and Chris
I installed Xprite headlights in my ‘15 JKU.
They come with the anti-flicker dongle and are plug in ready. I don’t remember if I had to trim a plastic tab or not but it was easy.
These have halos if you want them- just run a wire to the fusebox or leave them if you don’t.
I bought them on Amazon as well as a pair of their fog lights.
