Given the description of the issue and the solution provided, I think a vacuum leak under the intake is a great possibility, but how would that have caused all 3 cylinders to be so lean instead of only 1 of them?
Was there any evidence of a failed seal (pinched, damaged, etc.) on the injectors?
Just trying to picture where the failure was that could have affected all 3 cylinders.
Sounds to me like fiddling with the wire harness to swap the valve cover gasket has exposed a few poor connections and/or failing connectors.
Depends on what the root cause actually is… your vehicle; you decide.I just got done reading some of your other posts about that! I’ll pass that information on to my mechanic! Thanks! Secondary question will it hurt it to keep driving it?
Ran every test on it that he knew to run.
He did mention something about the cylinder head. Which I’ve read on here to about a cylinder head issue.
