2016 Manual Transmission very intermittent no start
Bobzilla71
Tehachapi
My Jeep has a very hard to find " No Start Problem " I've Changed the Ignition Switch, Battery, Tightened connections Starter is good.
When it happens, I turn the key and nothing, gauges come on with no click. Wait for a bit try key a few times then it will go.
But like I said its only once in awhile, no pattern very intermittent.
Any ideas?
Because it's manual doesn't the clutch have to be all the way to the floor for it to start I've seen it happen in standard Toyota pickup trucks where the clutch is not engaged all the way the floor or there's some type of mechanism or switch there that tells the starter to engage jeeps and electrical safety features nightmare
Did you read through this and try some of the troubleshooting suggestions?
Also is there a small red dot lit up in the right top corner of your dash cluster when it won't start?
