Thank you everyone in advance, I've searched believe me.
I have tried to do 200% of everything I can think of and I'm really at a loss for words.
I haven't made any mods to my jeep in over a year. Lets start with that.
IF I leave the M20 fuse in my lights will not turn off at all any of them. Doesnt matter if I have all the doors on or all the doors OFF.
I've even disconnected both pigtails on the turn signal stalk and the lights STILL stay on. Also, I don't think this is the issue because when I turn the headlights on the dimmer function works for the cluster lights. Also I noticed when the turn signal is plugged in if I make it go into the on position all the lights get brighter and when I move it off the on position they are still on but 90% power? Its like the difference of when your door is open and it you hit the manual button. Also hitting the button does nothing. either map light also the floor lights never turn off.
All of this happens no matter if the car is on/off in ACC. doesn't matter. Actually it might be a thing to note here. If the car is not on or no key in it, if I put the fuse back in the lights are off but if I try to hit a manual light button the light wont come on.
I've traced the wires the best I can without ripping the car apart completely but even after unplugging the wiring harness that is for the overhead dome lights the floor lights stay on as well.
I've unplugged the rear trunk dome light and the floor lights stay on as well.
I cannot find a wiring diagram to save my life on where the M20 fuse goes or where the grounds are.
Can anyone help me with this?
I really hope someone has seen this before
