I have a 2016 Jeep Sahara unlimited. I replaced the rear axle with new wheel bearing and seal. The speed sensor and abs light stayed on that led me to discover I was leaking axle gear oil. After replacing I have changed out speed sensor 3 times and cleaned axle around the teeth that are on axle and match to sensor, also check for power at connector and I have 12 volts. Any ideas?
Thanks
Thanks
