Got a leak on 2014 JKU  with 70k miles,  mechanic said he's seen quote a few of them..... First I've heard of this issue..    not to costly of a part but the process and labor isn't cheap.   anyone else have this issue?
				That is really is the name of the game. Like I said above I did the spark plugs at a later date, and I was most of the way to the oil cooler that I paid to have done. Torque specs are the annoying part for me because, while I have a 20 to 150 ft-lb wrench, everything in this operation requires something around 80 inch-lbs and is plastic.This is very common on the 3.6 Pentastar engine. Happened to my sisters 2016 Chrysler Town and Country minivan. My brother-in-law fixed it and said it wasn't that hard, mostly just time consuming because you had to remove a lot of crap to get to it.
My '14 had this problem as well. I bought it "certified used" so the dealership covered it. I think the newer units are less prone to breaking. Service manager said overtightening the filter housing causes stress cracks.
Yeah, @70k,might as well do the plugs. Labor is a b**ch for this, and is doable by a shade tree mechanic. I think there is a write up on the site for it.
Edit: here it is
3.6L Oil Filter / Oil Cooler Adaptor Housing Replacement
This is a basic Write-Up on how to repair the common oil cooler housing/adaptor leak. I will post as many photos as I can that will aid you, if you choose to tackle the project yourself. I will also supply a couple of picture that include ALL-DATA INFORMATION on torque specs and bolt torquing...wranglerjkforum.net
Quick Change Grease Monkey: "Well, you can put a socket on it, have to use power tools, right?"Thanks, doesn't look to bad. Probably from overtightening the filter cap... nice..
