One of the rear shocks was so hard to compress that I could barely make it move. It didn't feel that stiff on the road but I'm guessing it is a big contributor to why the Jeep feels like it's jumping across the road when you hit a pot hole or bump...
Back is in and break-in done. It rides so much better already that my daughter is going to think it's a new Jeep. The brakes feel much better too and it's only the rears that are new. The parking brake works 100% and it holds the Jeep still even on the steepest part of my driveway. The gears make cruising the hills in the area with OD on possible now. It adds a little bit of 'oomphf' off the line, but it's certainly not a V8 by any stretch of the imagination. My only wish was that the 42RLE wasn't so poorly programed - I swear it will shift into OD as low as ~20 mph.
Switching to the front axle today. The OTC adapters (#7894) arrived and boy, I'm not sure why I have never bought these before. That stupid little angled cup makes installation a breeze.
With the balljoints installed, the only thing that remains is finding the correct U-joint for the short-side shaft. I checked the axle that we removed and it also has a smaller joint than the passenger side. Once the old axle was out, I tackled the scale rust on the front of the frame. It looks worse than it is - there is absolutely no cancer anywhere but the person clearly parked this rig on a lawn or never rinsed this thing off in the winter, but all the chunky stuff has been knocked off and I'll give it a thorough coat of Eastwood Rust Encapsulator Pro.
These were up on Marketplace for a few days and have already sold... either I listed them too cheap ($800), or I just got lucky. I'm going to assume I just got lucky lol...
Despite the freezing AM temps, the midday highs still allowed me to get some paint on the cleaned up frame, brackets, and parts:
I ordered a set of new jounce bumpers but they were delayed in shipping, which means I couldn't get the front end fully assembled yet. I figured "no big deal", I'll just get the rest of the axle back together. Since my axle shafts have two different sized u-joints, I had to go down to AutoZone to get one that worked. As I started smacking it in place with my small brass hammer, one of the ends of the cap popped off! I could hardly believe it...
In a somewhat fit of rage, after getting extremely frustrated with these axle shafts (note that the long-side shaft needed the caps to be tack-welded in place since I could not get the clips in place at all locations!), I said f$#$ it and ordered a new set of Revo Discovery Shafts from Quadratec. Oddly enough, the 1350-joint shafts were on sale for cheaper than the 1310-joint shafts, plus they let me apply a 10% discount code. Looks like I grabbed the last set too, as they are now listed as "temporarily out of stock".
Putting CM shafts in a baby Dana 30 on 32" tires is 100% silly, but even the cheap eBay replacement axle shafts are over $500 for the set. These at least add some beef and have a warranty that I know Revo is good for...
Seriously I can't wait to be done with this side-quest project and get back to working on my JKU!! It will be nice having it all done before winter though, and I'm sure my daughter will appreciate the nice handling and ride, but I swear I ran into less headaches building the 14 Bolt than I did rebuilding these baby axles...
While waiting for the axle shafts to be delivered, I tackled another issue that's been plaguing the Islander - a leaky roof! With 1-2" of rain expected in a few days, I figured this was a good time to get this done...
Based on where the water was constantly coming in, I suspected it was the rear seal. According to the internets, this is a common issue. I ordered the Crown version from Quadratec (https://www.quadratec.com/p/crown-automotive/hard-top-seal-wrangler-jk-unlimited-68088040AA) a few weeks ago and got to work.
Many YouTube videos show people using Goo-Gone and a plastic scraper. Looking at the tape, it looked just like your typical emblem and trim 3M Adhesive Tape. I grabbed my rubber wheel and the material came off quickly and as expected. No issues with grit or rubbing the paint off the top either - it worked perfect and took just a few minutes.
I used some acetone and wipes any remnants of old adhesive and oils away. Again, there weren't any issues with paint and the acetone quickly softened and removed any remaining residue (you can see the black "specs" on the paper towel below).
Install was easy - I started in one corner and pushed in the plastic clip. I then peeled the adhesive tape cover away slowly, while pressing the seal in the groove that it sits in. Once I got to the center, I peeled a little bit of tape cover away so it wasn't going to get snagged by the two retaining clips, then followed the same process, being careful not to touch the exposed tape to the top without it being in place.
Install took about 20 minutes and you can tell how much thicker the seal is compared to the old one. I actually had to use the panel "screws" to help pull the Freedom Panels in place enough to allow the little "arms" to click into place.
Man I love those rubber wheels! Long ago I had to remove decals from a cargo van I purchased. That made quick work of it. I've found numerous uses for it since that time. Just not on any softer plastic unless you have a really soft touch!
Reactions: pc1p
Same here - I remember grabbing it somewhat recently to remove some adhesive tape that someone had left over when they removed a set of aftermarket window "vents". He was losing his mind trying to find something to dissolve the foam tape with no luck. I grabbed this and we got all 4 windows cleaned up in less than 5 minutes. He spent 10x as long trying to clean up the driver-side window and wasn't even close to getting done.
Right tools for the job certainly makes life easier!
These showed up yesterday afternoon and I had them smacked together in about 15 minutes... gotta love fresh, clean shafts!
Spent a few hours yesterday evening getting it all buttoned up and then torqued down everything today on my lunch break...
My sore shoulders, hips, back, and hand/arm muscles were worth it - the Islander rides great! Although I still want to bleed them, the brakes feel fantastic (they're the Duralast Golds from my JKU), the ride is fantastic and the rig feels nicely planted around corners and on washed out dirt roads, and the gears seem quiet and smooth.
I'm taking a week off from any Jeep work and will focus on some pre-winter house things on my "Honey Do" list... At least now I can clean up the garage a bit and enjoy a short break before getting to work on my JKU...
I said I wasn't going to work on the Jeep for a few days...
I got the garage cleaned, the trash all cleaned up, some old parts sold off, scrap metal brought to the recycler and the Hemi was just sitting there looking at me. So I did what any sane person would do - start the disassembly process:
I pulled the intake, disconnected all the MDS nonsense, used a scraper to loosen up the dirt in all the nooks and crannies, and then put some tape across the intake ports to prevent any crud from getting down in there while I continued to clean...
In case you missed it in the earlier pages, it's a 2010 Ram 1500 5.7L. In stock form, she's good for 390hp/407tq as rated from the factory, though most people that swap tend to get a little more juice out of them. I'm planning on adding the BTR VVT "Truck Norris" Cam, which should add some much appreciated kick.
According to BTR:
"Approaching 490 HP at the crank of your 5.7L Hemi is what you can expect with our ‘Truck Norris’ camshaft. This ‘Truck Norris’ grind gives an additional 1500 RPM of usable operating range while maintaining drivability. On the BTR Dyno, we saw gains over the factory cam everywhere above the 2000 RPM start point. At 6000 RPM, a gain of 71 HP and 62 lb/ft. The ‘Truck Norris’ continues to pull strong to 7000 RPM!"
With the 8-speed 8HP70, she should have lots of nice driveability and more than enough power for 39" tires or bigger!
Most of the time I feel like the trans is the only part of the JL I really envy. Then, of course, like any sane motorhead, I start going down the rabbit hole. I can swap in an 8spd, but if I do that I might as well do an engine swap, and that might as well be a 5.7. Then I should upgrade the front to a 44 and might as well do gears at that time... and, and, and. 😂
So, for now, I'll live vicariously through you @pc1p
  • Haha
Reactions: pc1p
It is certainly a slippery slope…
Admittedly, I got an older, high-mile JKU with the intention of Hemi swapping it. Had I gotten a newer 3.6L model, I may have kept the 3.6L but would absolutely have considered a 8HP swap - it’s such a smooth trans…
I think I would have kept my 3.8 if I had a chance for a new 8HP transmission. I honestly don't feel the desire for my Jeep to have as much HP as my Mustang.
To each their own though, incredible build so far!
Reactions: pc1p and tJKrider
I hate underpowered rigs only second to undergeared rigs... For me, on a JK with 35"s and proper gearing, 300hp/300tq is a very useable and streetable number that I would be happy with. I think you make a valid point in that the 3.8L isn't terrible, though that 42RLE is a power-robbing vampire that has gear ratios that don't fit any situation or driving speed. A ZF trans would certainly help a bit there. The JL at 285hp is good for a stock rig, and the ZF 8-speed makes up for instances where bigger tires are added, though I would almost certainly opt for the 392 cid if I were to get a new-new Jeep and had plans for anything bigger than 35"s.
I cut my metaphorical teeth on big-block equipped, full-sized rigs (back when 38.5" tires were "massive"!), so plenty of horsepower and gobs of torque on tap make driving much more enjoyable for me. Oddly, I've broken less parts when I've had over-powered rigs vs under-powered rigs. I'll take too-much power over not-enough any day of the week :)
I've been so busy with wrapping up the Islander and some house stuff, now it feels like I've got nothing to do... so back in the garage I go haha...
I had some space in the trash, so figured I might as well use it up (trash and recycling space comes at a premium during the holidays!). Since I'm planning on replacing the carpet with a BedRug, I figured I might as well get the carpet torn out and disposed of. The carpet is clean in some spots and absolutely torn to shred in others. No idea what people are doing with these things at times, but this thing did have a bit of a "funk" to it. I'll be glad to have it out of the Jeep and garage...
I then turned my efforts back to the Hemi. Unfortunately, I got some bad news...
Looks like this engine won't work for me after all. I'll strip off some good parts and then turn my attention back to sourcing a good swap candidate.
That's the thing when you are searching for a swap candidate, You have no idea what is really underneath until you get inside them. I tried 3 swap candidates before I went with a crate LS3.
