It's all about turning your brick into a race car, man. We all should have gotten Corvettes instead.
No sir, If I wanted/needed a compensator I would drive an F350 lifted about 20 Inches on 52's.
Not really. It's also about not turning into a rolling road block. That may not be an issue if you're in the flatlands, but it certainly is in Colorado.It's all about turning your brick into a race car, man.
I'd change "instead" to "as well"... I have a C5 making 850HP. You can have more than one toy.We all should have gotten Corvettes instead.
I'd change "instead" to "as well"... I have a C5 making 850HP. You can have more than one toy.![]()
Then people would be asking about CAI and TB spacers…
Curiously, how does adding zero torque or HP help with the hills and elevation of Colorado??
It doesn't, obviously. The context of the post you replied to was clear, I thought. I think things like pedal commander are pretty much useless. Building a more powerful engine is the answer.
No. Not a Jeep. I have driven other brands though. I see no reason to think that those would do anything different to the pedal commander. Do you?Have you ever driven a Jeep with a throttle pedal enhancer?
You can't really enhance the 3.8, you can just make it feel like it's peppier.
I honestly cannot wait until I regear because I live in a very mountainous region and even with 4.10s, it's torturous.
I have, a handful actually...Have you ever driven a Jeep with a throttle pedal enhancer?
Again, it's important to clarify expectations/descriptions here. It doesn't "make it move faster", but "move the same speed with less throttle input". If that's how you would describe "move faster" then so be it. The only thing the pedal commander is doing is changing the throttle pedal to throttle-blade response ratio. That's it. It's basically doing the same thing to your brain that new basketball shoes does to every 4th grader.Yes it does make it move faster then not having one, I have a Pedal Commander.
But like you and others have said if you really want performance then a different engine or gears would also help.
