Zero oil pressure no matter what
Tacoman1998
Golden, Colorado
I just recently replaced the timing cover gasket due to a coolant leak on my 07 JK unlimited with the 3.8 V6. Simply replaced the gasket, bolted everything on, and went to start, only to find I was getting no oil pressure at all due to the idiot light being on and the engine started knocking. I think I’ve ruled out bearings, oil pickup being clogged, and the oil pump being bad given I didn’t take it apart. I tried ‘priming’ the system by overfilling the oil level (10 quarts) and cranking the engine over with the oil filter off, but nothing came out after 8 cranks. My only other thought is maybe I need to pressurize the system some other way? Does anyone have any ideas/ experience with this? Thanks in advance.
I haven't done priming on the 3.8 but have on another motor. I pulled the relay to not flood the motor. I pulled the plugs to give as little resistance when cranking.
What was the conclusion ? Going through this also , have primed motor by pumping 1 gallon of oil through the oil sensor port. On 2 occasions not priming after either attempts.
