XL Heavy-duty Tailgate table. No drilling!🔥
WHEELSFEELS
Houston, Texas
Upgrade your Jeep Wrangler with our high-quality tailgate table, boasting an automatic one-handed opening and secure closure powered by durable gas lifts
  • Tailored uniquely for Wrangler JL, JK, and 4xe (4 and 2 doors), maximizing every space.
  • Extra-large tabletop L13" * W16" * H12".
  • Heavy-duty. Load up to 60 lbs.
  • Storing, cooking, eating, or working space. Fits all your needs.
  • Custom designed and made in the USA.
  • 1-year warranty.
  • Free shipping in the USA! Worldwide shipping.
This company should not get your business. They do not make products with a decent turnaround time. When there are problems, they do not stand behind their product. Avoid.
March 10 - Ordered a tailgate table
March 31 - Shipped
April 11 - Delivered
April 12 - Opened package, took pictures of damage, installed table
April 27 - Used it for lunch and the wood snapped while gently closing it; contacted for help
May 1 - My repairs didn't work; requested replacement under warranty
May 13 - "We plan to ship a new table to you by the end of the week."
June 3 - I requested info (no reply)
June 10 - Again, requested help
June 12 - "... and will send you a replacement this Friday."
Followups throughout June and it's now August.
  • Wow
March 31 - Shipped
If you haven't disputed the charges with your CC then you are a damned fool.
I'll take that criticism. It's difficult to dispute the charges when I did receive a table, I'm attempting to get warranty work done, the company was claiming to work with me, and that much time elapsed (payment was in March, warranty repair started May). I posted my note as only a cautionary tale.
Here are pictures of the old table. One showing the damage upon receipt, the next with the hinge supports all splitting at the same time from simply closing the table, and a third showing a weak joint near the strut and nailing into the edge of plywood.
On the same day that I posted negative reviews, I also contacted the company about these negative reviews. The next day I had a table being shipped and it arrived yesterday. The company cited "design changes" as their reason for delays twice. After a very thorough review of the construction and comparing the two with a tape measure, I can find no design changes. Unfortunately I did find a couple of paint issues and a dent in the plywood. Very disappointing to see that on my replacement. I also noticed that both tables must extend down a bit too far because my carpeting was rubbing away.
On the new table, I decided to void my table's "warranty" and fix what I could. Instead of having bolts that simply get screwed into the wood (lots of wishful thinking there - my bolts pulled out of the wood), I replaced them with slightly longer bolts and added nuts to help with the shear force that the hinges exert. My belt sander also took down the bottoms of the hinge areas by a quarter inch to help preserve the carpeting.
Edit: The right side strut just pulled out of the table. I didn't put any weight on it and merely tested opening and closing the table a couple times.
I really like the design and how it is intended to work.
  • Installation is a breeze.
  • The solid back covers up the unsightly area where the smaller plastic part was removed from the tailgate.
  • The one-handed operation is wonderful.
  • It holds a decent amount of weight.
Removing 1/4" from the bottom, using slightly longer bolts and adding lock washers (with internal teeth) and nuts seem to be the major fixes that are needed. I might need to reinforce the strut area with sheet metal. The high-stress areas seem to align the stresses with the layers of plywood, which is the weakest part. Plus there's the top of the strut that's nailed into the edge of the plywood - I don't know of anyone who thinks that attaching plywood at the sides is a good idea.
Edit: Looks like I will be drilling through the table where the screws hold the struts in place so I can put more bolts in.
However, the turd in the soup is the terrible customer service.
  • The initial order took weeks to leave their facility.
  • Their email address stopped working and started bouncing.
  • The online chat was non-responsive half of the time, even though it clearly said that someone had read my message.
  • They never reached out to me to explain a delay or to let me know; all of the communication was initiated by me.
  • They appear to have lied about the product redesigns.
  • The replacement table has defects.
I don't think that the company realizes that terrible customer service means your company tanks due to reputation, but amazing customer service can get customers to still be happy even when there are issues.
View attachment 127720View attachment 127719View attachment 127717
View attachment 127715View attachment 127721
View attachment 127718View attachment 127724
I understand the desire to have such a table, but if you put that much work and effort into fixing the one you bought, then you're a damned fool for that too! ;)
BTW, I own 2 Wranglers, so I'm also a damned fool, but at least I didn't spend all that time and money buying and modifying a box of parts to build my own folding tailgate table. 🫣
Continuing the story to its completion.
Another person got in touch with me and I learned a bit more. They issued a refund on July 28, but it did not go through until mid September. I suspect there was an issue giving the refund because it was after a 90-day window or something similar and they had to contact another company to get this sorted. I've been told the design has changed again but was provided no further details.
Would I recommend this company to a friend? It depends. I just got back from a long road trip and used my modified table quite a bit. With my modifications, the table is excellent. If my friend didn't need a table right away and was willing to make small modifications (assuming the company didn't fix the design), then yes I would recommend the company. If the table needed to show up quickly, if it must not require modifications, or if having helpful customer support is important then no.
I would love to know if others have worked with this company and what their experience has been like. Also, in the unlikely possibility of getting details of the design changes, I will try to update this thread.
