Hello! I have a 2010 Jeep Wrangler Rubicon Unlimited and recently ran into an issue with the center control panel. I went to turn up the fan speed, and suddenly everything on the control panel went dark and the climate control fan stopped running. I later found out when I got home that my hazards, axle locks, diff disconnect, traction control, and 12v outlets also are not working. However, while trouble shooting, I found that if I shut my door harder than normal, everything boots back up. If I shut it hard again or change the fan speed, everything shuts down. I've checked all of the fused associated with the control panel, cleaned and tightened the associated ground points, and am still having the same issue. Any idea what else could be causing this?
Thanks for the help!
Ben
Ben
