Wiring diagram for 2 rear connectors -‘15 Rubicon
WestCoastDan
SoCal
Can anyone shed light on where to get the wiring diagrams for these 2 connectors in the rear of our ‘15 Rubicon?
I’m wondering if there is a potential wire to tap my USB port into.
My USB port has a switch built in, so finding a constant hot would be ideal.
I am prepared to just extend the power from the center console back to the new dual port plug if needed.
The small plug is for the 12v outlet if you had the sub and socket. I am deleting my sub and 12v out and putting a new 12v into the delete kit. I will be tapping into that plug, but I’ll have the other side and wiring since I already have the socket.
If you never had those I am pretty sure you will need to add a fuse in the fuse block because yours will mostly likely be empty.
I'm guessing that once a fuse is present, the 12V is only hot when the ignition/radio are on if it was to power the subwoofer.
I'm looking for a constant hot source, since my USB already has a switch & I would prefer to not need to turn the ignition on for it to have power (too many other power drains w/ignition on.)
My rear 12v is always hot.
Thanks, I'll definitely have to dig out the meter and check.
Any clue what fuse would control that circuit?
I think I found it... 20A fuse shown as #M7.
Looks like this is going to be easier than I thought... when does that happen with a Jeep?
