Ok, I have an 08 3.8L 6 speed manual. No major upgrades. For two years I have been fighting a no-start issue when the outside temperature is above 65F, or so. The ONLY code it ever throws heat related is bank 2 sensor 2.
So, the problem is, I can cold start in the morning with no issues. However, after driving around for 20-30 minutes, if I turn it off, no start! All electrical works as normal, jumping off does nothing. I can push and pop all day long, but that gets pretty annoying and cannot be done everywhere. Now, yesterday, it was about 91 degrees, and I went out to start it at lunch, 3 hours after getting to work, and no start! I should mention that normally it takes 1 1/2 - 2 hours waiting for it to start back on its own, less when putting a fan blowing up on the engine. I have replaced the starter, tested out a new ignition switch, etc, etc. I am at my wit's end and really could use some help.
Any ideas? Thanks in advance, friends.
