Whistling from light bar
stinlubik
Vandergrift, PA
I had just put a new 50" LED light bar above my windshield. And now when I hit 30 mph, I am getting a lot of wind noise and it gets worse the faster I go. Is there any way to stop the wind noise?
Have you tried angling it down a little that seemed to work for mine? If that doesn't work i've read about a dozen other fixes for the noise but don't know which one works the best. I'll let you read and decide which one you want to try.
These do the trick:
https://www.amazon.com/dp/B0106FHAKQ/?tag=jkforum-20
Also, this method works as well:
These do the trick:
How do those work? If I angle one way it whistles loud if I angle straight or the other way vibrates 40+ mph. How do I stop that
Every person with a light bar I've spoken to has the same issue. But:
This guy uses a vinyl baseboard molding found in the flooring section of your local Lowe's.
Reactions: FLCoastJK
Just joined JKforum and saw your question. There is a fantastic solutio, Aerolidz. I tried everything and nothing worked until Iput on the aerolidz. https://aeroxindustries.com/
added pic of mine with the Rubicon insert.
Reactions: FLCoastJK and mrjp
