R Rob Edwards New Member Joined Feb 1, 2022 Messages 5 Location 13 Currajong Avenue, Camberwell Victoria Australia Apr 14, 2023 #1 When I attempt to use the OBDII scanner J-Scan do I need to buy a fitting that fits into the socket to red the codes? thank you in advance
Snowbird Tom JK Enthusiast Supporting Member Joined Mar 19, 2023 Messages 452 Location Michigan Apr 14, 2023 #2 Yes, on the JScan website is a list of all the compatible OBDII adapters. https://jscan.net/supported-and-not-supported-obd-adapters/ Reactions: mrjp
JerryD ¯\_(ツ)_/¯ Supporting Member Joined Dec 20, 2019 Messages 923 Location West Michigan Apr 14, 2023 #3 Yup, you'll need an adapter that plugs in to the port. Go to https://jscan.net/supported-and-not-supported-obd-adapters/ Reactions: Snowbird Tom and mrjp
Snowbird Tom JK Enthusiast Supporting Member Joined Mar 19, 2023 Messages 452 Location Michigan Apr 15, 2023 #4 JerryD said: Yup, you'll need an adapter that plugs in to the port. Go to https://jscan.net/supported-and-not-supported-obd-adapters/ Click to expand... Great minds think alike. Reactions: JerryD
Anybodyhome USN Retired (1973-1993) Supporting Member Joined Jun 15, 2020 Messages 1,653 Location Nashville, NC Apr 15, 2023 #5 Mine: https://www.amazon.com/dp/B06XGB4873/?tag=jkforum-20
S snipers New Member Joined Mar 31, 2023 Messages 1 Location KSA Apr 15, 2023 #6 Snowbird Tom said: Great minds think alike. Click to expand... you may look for Icar Pro OBDII https://www.amazon.com/dp/B06XGB4873/?tag=jkforum-20 you can connect via Bluetooth or Wifi , both device and OBD JSCAN
JerryD ¯\_(ツ)_/¯ Supporting Member Joined Dec 20, 2019 Messages 923 Location West Michigan Apr 15, 2023 #7 Anybodyhome said: Mine: https://www.amazon.com/dp/B06XGB4873/?tag=jkforum-20 Click to expand... I have one of these and it works better with J scan than a couple more expensive dongles I have.
Snowbird Tom JK Enthusiast Supporting Member Joined Mar 19, 2023 Messages 452 Location Michigan Apr 15, 2023 #8 JerryD said: I have one of these and it works better with J scan than a couple more expensive dongles I have. Click to expand... Ditto! Pretty simple to comprehend when you just start the learning curve.
Chris Administrator Staff Member Joined Sep 28, 2015 Messages 32,519 Location Gillette, WY Apr 15, 2023 #9 This one always does the trick for my https://www.amazon.com/dp/B06XGB4873/?tag=jkforum-20 Reactions: JerryD and mrjp
