What parts are necessary to install a 3-1/2 lift from an existing 2-1/2 inch lift?
J May
Delray Beach, FL
Looking at lift kits but they include parts I don't need.
Already installed heavy duty steering.
Have 35" tires and Bilstein shocks.
You'll need a new front driveshaft, adjustable track bars front and rear, and adjustable control arms front and rear. Unless you already have any of those parts. Also possibly longer brake lines, and a alignment.
Reactions: Duster and Danarch
Thank you for the informaiton -
Question - Will I need a new rear draftshaft too? Can you explain why front driveshaft is important?
Not sure about the rear but on the front it's the joint at the T-Case that causes the problem with a lift over 2.5".
Reactions: Duster
Can you review the attached part list and provide your thoughts?
looks like everything you'd need, is it cheaper to buy different Brands than to buy a kit from one Brand?
I don't have any experience in which Brands are good other then stay away from Rough Country.
He listed their track bar and brake lines, I would have no problem with either of those items. It’s their springs I’m not a fan of.
When you think about what a lift does, it moves the body mounted portions of the suspension upward. It does not affect the differentials, which are mounted in the axle assembly. They are affected only by tire diameter. So a lift kit will improve your cross-over clearance without changing the front or rear ground clearances. The front drive shaft is placed at a steeper angle from the transfer case to the front differential, which increases stress on the articulation points where it leaves the transfer case, and where it enters the front differential. The differential end sees more stress because the axle travels more than the body end. Bigger tires improve the clearance of the differentials, but they don't change the geometry between the lifted elements and the axles. Those steeper angular transfer points are likely trouble spots; they are trouble even in unlifted vehicles, so higher lifts call for adjusting the linkages that connect the body mounted suspension element ends and the axles. The chief things I would look for are the track bars, sway bar linkages, drag link, and control arms. All of those change their angles of articulation when lifted.
