I'm getting a misfire on cylinder 5 and have decided to go ahead and do the plugs and maybe coil packs. I'm only approaching 60k miles though, so that's kind of disappointing if they're failing already. That being said, should I consider going all the way to the oil cooler under the intake? Mine is NOT leaking, but it seems like you're halfway there while doing the driver side plugs. Are the aftermarket units better? Are the later OEM units better? Am I better off not touching it? What would you fellow Jeepers do?
Thanks!
T
Thanks!
T
