Its right behind the washer fluid tank at the bottom and just snaps in. If you pull it out away from the tank fluid will flow out of the tank so that will tell you if the pump is getting fluid.
And of course, check the nozzles to see if they are clogged. If you wax the vehicle, it's common to get carnauba wax in the nozzles which clogs them so they can't spray.
