I bought this 09 jk already lifted and everything done to it. From when I bought it it always had flighty steering and a loose steering wheel (Probably about half an inch to inch of play in steering wheel). Anything over 25mph and it will be flighty. Highway speeds and hitting bumps is almost dangerous. It’s not a death wobble but will definitely try to kick me into other lanes. I’ve replaced the ball joints and checked my toe in and caster angle  and everything is tight. I can’t tell if any of my drag link, tie rods or any other joints seem loose. I noticed it looks like my steering box could be leaking. Occasionally when I’m pulling into a parking spot or slow speeds with tight turns the steering acts like it cuts out for a minute but haven’t heard any whining or noise come from it. I just want to get other opinions on it before I dump the money into replacing the steer box also to avoid putting a bandaid over the actual problem and possibly messing up another steer box. I’m not 100% sure on what lift size it has from the measurements I found to do online it looks like possibly a 4inch lift. Help with determining that would be great too. It has 33” tires on it and upper and lower adjustable control arms in the rear and just lower adjustable control arms in the front.
