Just wondering if this might be causing my wandering or if it’s normal.
Those tie rod ends are supposed to rotate like that. Like gentleman above stated: caster, toe in or out. IMO not so much tire pressure, unless maybe you're running extremely heavy, large tires. I had some awful wandering and it was my ball joints. The alignment was off as well so it was really a shifty ride.
psi was 35 on 3 of 4 tires and I dropped it to 30. I might go lower, need to do a chalk test but it would probably be easier to just drop it and see if it helps (I don't have any chalk). 37" tires so there is defiantly weight. I'm talking to a local offroad shop about doing an alignment. I'm guessing the ball joints or caster is off. I could probably roughly check the caster at home but it won't be as accurate as the shop.
Have you checked to see if the axles are centered under the Jeep?
I'll add that to the list. I would think it would be pretty easy and quick.
