hello,
So I just did a gear swap on my jeep. I have 33s so I decided to go with 4.56 gears. After changing parts that needed to be changed such as spider gears in the rear I finically got my jeep up and running. However, when I took it for a test drive, it won’t shift out of first gear. And when I stop and put it in park then try to either put it in reverse or drive, it won’t go into gear at all. I have to turn the jeep off then start it back up in order to get it into gear. I’m replacing my engine oil pressure sensor here with in the next few hours. Can anyone tell me what else it could be if that doesn’t work? The sensor needs to be changed regardless so I’m not changing it for the transmission. I also looked for transmission pressure switch but can’t seam to find one ANYWHERE. does anyone have any ideas or perfections or information that would help. I really appreciate it
