Transmission help
rcluk89
Pennsylvania
2012 jeep wrangler sport. I've have replaced everything there is to replace on the transmission side of things and thr jeep still won't move it has the nag 1 in it and it been rebuild twice and new valve bodys yes bodys!!. Also new togure converter and tcm...I would appreciate any info to try and get this this to move again
What do you mean "will not move"? Like, will you feel it go into gear but when you press the accelerator, LITERALLY nothing happens?
Are you getting any transmission/CEL codes? T-case is in good shape and solidly in gear (the t-case shift cable is notorious for jumping off the stud)?
