I have a 2013 JKu Sahara Automatic with 3.73 gears and the towing package. It is rated to tow 3,500 lbs. I would like to tow a 3,443 lb R-Pod 192 travel trailer. I plan on towing with empty tanks and get our supplies and groceries near our destination. I know It will be at the published limit for the vehicle. When I compared the JK to the same year Grand Cherokee with the same engine and transmission the GC is rated to tow 5,000 lbs. The GC has a slightly shorter wheelbase and slightly wider track. The GC has IRS which I believed to be weaker to the D44 in the JK.
So...
Do you have experience towing with a similar JK and a similar weight travel trailer? If so what are your experiences?
And...
Any ideas why the Grand Cherokee is rated to tow 1,500 lbs more?
Thank you fellow Jeepers.
Dan
So...
And...
Dan
