Just got a flat and it's time for new tires. Currently running 265/70R17's on a 2015 JK with a 2.5" Rough Country lift and quick disconnects. This tires look so small in the wheel wells. How much larger can I go without issues?
Looks great!You can squeeze a set of 37s under the fenders.
I have a 2.5" lift with 35 x 12.5 x 18:
Regearing is a good idea, almost mandatory. BUT... it depends on the terrain. In Tennessee, yeah I can see it being a royal pain, but Michigan is mostly flat-ish, especially along I-75. I have 35's, 3.73 gears and can run 80 on the highway no problem. The 3.6 makes a big difference, too. That said, 4.56's are in my future (I'll never go larger than 35's).If you go with aftermarket wheels with 3 1/2" back spacing 35's fit great. But you will have to change your gears. People will tell you that they are running 35's without a gear swap, but I guarantee they have problems on hills and keeping up at highway speeds. 4.56 gears worked perfectly for my manual transmission.
I'd be curious what your RPM's are at 80. I recently went to 35's with stock 3.21 gears. I'm in Florida, completely flat. I haven't done highway speeds yet, most is 60 going to/from work. I can feel the difference with the 35's. I can probably stay with them but do plan on 4.56 change out after I pay my taxes. I don't remember my RPM's at 60 but know it doesn't go into 5th (automatic) until I hit 50-55.Regearing is a good idea, almost mandatory. BUT... it depends on the terrain. In Tennessee, yeah I can see it being a royal pain, but Michigan is mostly flat-ish, especially along I-75. I have 35's, 3.73 gears and can run 80 on the highway no problem. The 3.6 makes a big difference, too. That said, 4.56's are in my future (I'll never go larger than 35's).
Also, if you have the D30 up front, anything larger than 35's will likely require some beefier components up front eventually, too.
Well, truth be told, I don't like going 80 in the Jeep - usually it's when I'm keeping up with traffic and then I'll let it go back to 73-75 when the limit is 75. I can't recall the ACTUAL tire size of my 35's but assuming they are for the sake of argument, and using an online calculator, I'm turning ~2865 at 80mph. Same conditions but with 3.21 gears and I'd be at 2465. With 4.56 gears, it would be a shade over 3500.I'd be curious what your RPM's are at 80. I recently went to 35's with stock 3.21 gears. I'm in Florida, completely flat. I haven't done highway speeds yet, most is 60 going to/from work. I can feel the difference with the 35's. I can probably stay with them but do plan on 4.56 change out after I pay my taxes. I don't remember my RPM's at 60 but know it doesn't go into 5th (automatic) until I hit 50-55.
I have a automatic, but 35s with 4.10 gears I run about 2500 RPM on the highway at 75/80.I'd be curious what your RPM's are at 80. I recently went to 35's with stock 3.21 gears. I'm in Florida, completely flat. I haven't done highway speeds yet, most is 60 going to/from work. I can feel the difference with the 35's. I can probably stay with them but do plan on 4.56 change out after I pay my taxes. I don't remember my RPM's at 60 but know it doesn't go into 5th (automatic) until I hit 50-55.
